worked ssv
Gday guys
Got a few more questions regarding my vk I'm doing a 304 conversion and recently got hold of a vs 5l fuel tank for it question is would this be a straight bolt up or am I going to have issues? What's the go with the fuel sender should my vk Calais wires match in with the Vs wiring from the sender? Will my vk tank straps fit or do I use the vs ones and modify those? I also left the vk k frame and power steering rack In bolted in the 304(from a Vn) and went to hook up my power steering lines to the vk rack but had issues, are the treads on the Vn power steering lines the same as the threads in the vk rack or am I going to have to get lines made? If so does anyone know what threads I need? Or can I somehow hook up my vk power steering lines to my Vn pump? Cheers guys
