vk v8 calais
Geoff308
Sydney NSW
Vk calais
New to forum thought I would post a couple of pictures of my vk that I have owned for 12 years only just started to finish it off and drive it until ignition module sh#t its self.
vt clubsport 5lt engine and box
vt booster/master cylinder and brakes
355 lsd rebuilt 4 pinion
19 hdt aeros
original leather interior.
drives well.
looking for info on anyone that rebuilds the ignition modules as I don't want buy cheap copies or anyone that knows how to contact nucular power modules that used to rebuild them?
gtrboyy
vt ss & lc gtr
Checked fault codes?
Noid light off injector harness for signal?
Swapped ignition module to known working unit to be 100% that is the issue?
Geoff308
Sydney NSW
Vk calais
I have done the by 5lt ingnition test that says to suspect faulty ingnition module see attached.
no injected pulse
Coil checks out ok
Codes 49 intermittent crack signal seems to be a common vt problem.
Code 35 idle speed error
I don’t have another ignition module or know anyone with a 5lt that I can try my IM on.
gtrboyy
vt ss & lc gtr
I'd be thinking signal issue from sequential dissy or probably loose plug/wire associated with it.
Normally when ignition module is cactus it's like coil either works or it doesn't unless starts to play up when cooks itself.
Codes don't come up for ignition module which is why I'd test dissy or wiring/loose plug or earths first.
