B
basterdvl
Guest
I have a vl exc 6cyl auto extractors 21/4 exhaust.
I am having trouble with big flat spot when the throttle is bliped. also base timing is hard to set as at 15* btdc it pings badley. It has had new dist cap rotor leads and plugs not so long ago. I C/o the air flow sensor and it idles a lot more politely but i cant tune out the flat spot. am thinking poor calibration of the throtle position sensor? plugs are very lean. (white like new not 3 months old) Any info or spects on testing and adjusting these sensor would be appreciated.
