Vl turbo conversion
kdiz22
VY Storm Ute
do i have to change my computer and my air flow meter when i put a stock turbo on my vl rb30... any help would be appriciated
cheers:)
Panama
'87 VL Calais with L67
yeahn computer and injectors. not afm though
VLDavo
lc torana. vn v8. ke30.mazda 1300.
you can run a n/a comp and injectors just dont go over 7psi or the injectors will max out soon after that
VL Formula Turbo
South Eastern Melbourne
VL Formula Turbo
The injectors r different to turbo ones AFM is the same computer is different wiring loom is different in the loom there is one more wire on the turbo models that is the knock sensor this reads pinging
kdiz22
VY Storm Ute
thanks for that,
how much psi do u think i can run with fully oversize rebuilt engine bottom to top with crow comp cam, oversize valve springs, 8.5.1 piston tops, t70 turbo, intercooler and oversize injectors? would i be able to run 15 psi or more?
nasty1
adelaide
vy2 clubsport
should do mate but youl need to get at least a nistune ecu to run bigger injectors and that much boost.
im running the same gear as you with stock ecu and stock injectors and on 12 psi its fine no pinging or anything
Goon
Scientific Tuning
BrisVegas. QLD
VY CUSTOM.
so u can run a n/a computer under 7 psi? what about the n/a automatic transmission computer? Or the AT2 whatever its called the turbo auto computer? sorry to steal someone elses thunder here.... lol
starfire vc
now on 10 pound
Brisbane,North
VL turbo, RB30ET VH wagon, 64 EH in the build.
this has been done to death on calais turbo.definatley do not use n/a computer and injectors as it just wont work. standard AFM will support around 200rwk
kdiz22
VY Storm Ute
Where would be the best place to get aftermarket ecu, injectors and afm to support up to 300rwk
cheers thanks for all the help guys :)
VL_5SPEED
Newcasstle
1986 Holden VL calais project
From what ive heard, na injectors and na ecu are fine to run with turbo. Just dont add more boost.
