VN external door handle
Pooch88
35
Vn vz
Hey guys. Bit stuck on remove the door the external door handle. I gotta the spring clip off but there's no bolts or anything to listen the handle...
VPRob
nowra, NSW
VP executive sedan V6
having trouble understanding your query......
rambunctious
Alexandra Headland Qld
VZ Executive Wagon
I can't remember the vn but
If it is same as a vz there are 2 x 10mm nuts accessed from inside the door after removing door trim.
You have to disconnect the rod off the handle lever first then undo the 2 nuts.
HarryHoudini
Australia
1991 VN Wagon..2012 VE Sportwagon.
Yes,IIRC there are 2 little bolts inside,complicated little thing for a door handle,the guy who designed it had too much time on his hands,Dealer told me it was of German origins(Opel).
HSV126
Briggs & Stratton
I really dont think its the parts that are the problem..
Replaced mine with VS cast handles on all 3 of my old cars
