quaddy already has a pivot hole in the throttle linkage which is the correct throw distance from the throttle cable pivot. the TVS needs to be a "pull" and on my impala (throttle is also a pull) and needed to be a little lower than the throttle cable due to a short throttle pedal throw. TVS needs to be set pretty much full open at full throttle and partially pulled (i.e. no slack) at zero thottle so the tvs valve goes to the correct position at partial throttle. it all really depends on your throttle pedals amount of travel and you will need to get the trans shift pressure checked when you are sure its right. a poorly set TVS will hold gears too long, or shift too early and will burn out your clutches, so its best to get it all thoroughly checked after its set up. luckily for you the VN will already have the correct throttle-TVS throw distances, so im pretty sure they should connect to the same point on the carb, but could be wrong.
