savage1987
Donating Member
- May 8, 2005
- 3,660
- 31
- 48
- Location
- Townsville
- Website
- www.facebook.com
- LS1 VN + WK Grange 0010 + HPW VX SS
developed quite a problem with melting its underbonnet fuses.. not blowing the fuses, just melting them and the housings.... wtf could cause this?
fuel pump, engine fan, headlights and high beams all melted badly the other night. I'm guessing an earth somewhere(??) but somebody clued up in electronics pleeease give me some ideas. I'm lost with it.
I've had a few ideas so far..
1. engine swap to LS1 has no dedicated earth from engine to chassis - only earths via starter harness-->neg terminal-->body.
2. neg terminal-->body earth is ****, it's a bit of (thick ish) speaker wire. would this cause the problem?
I thought it was just because I was running an uprated fuel pump (Walbro 255lph) on stock wiring, and AU thermo fans also on stock wiring (although they are on an inline fuse instead of the blade becasue that got bloody hot from the massive draw the fans put on the system..)
HOWEVER
the headlights and high beams melted theirs also, the high beams worst of all. They are totally stock systems.
The headlights and high beams also went out the other night for no reason, only once in a couple of hours' driving, and only for a second, but they did go out, so I don't know what the hell is going on there.
Help appreciated, I don't want to go tearing **** apart and rewiring things unless I have to, I have minimal time to sort this out as I have a 4000km trip coming up in a couple of weeks and do not feel like getting stuck on the nullarbor would be particularly awesome.
Thanks
Sam
HOWEVER
Thanks
Sam
