If it is still leaking then I would say the seal has been damaged or moved upon installation. Did you buy the seal in a kit? If not you may have bought the wrong size seal. They should be a tight fit and take a bit to get the resi back in once the seal has been replaced. Best to put some Vaseline on the seal to get the resi back in. The resi's can crack. If none of the above is your issue, I would looking for cracks.
