JoshSvc
- Oct 15, 2008
- 144
- 2
- 0
- Location
- Central Coast, NSW
- VN Sedan - The Beige Bandit!
Okay guys, i've had the VN S1 V6 for about 6 months now and she is having afew issues.
Small engine knock that rises and falls with revs.
Rattle like marbles in a can, more so when in Drive and when under load - But not when the engine is cold when its cold of a morning it has no noise at all.
Vibration when the car hits 80kph which i'm assuming is the infamous torque converter lock up so it will need to be replaced.
Engine has been serviced, transmission oil is a bright red i havent serviced it yet as the torque converter has to come out and be replaced and i didnt want to service it if there is crap in the converter.
I'm thinking a damaged rod is causing the knock so the engine is up for a rebuild and the transmission either needs a full service or replacing as well, i would happily convert it to a 5 speed manual but i plan on using the car for towing.
Any other ideas?
Any other ideas?
