Vn ss knock then shudder when acclerating from 80 pls help
sootty grunter
wa
vn ss
hi guys just bought this car... when cruzing at about 80 then accelerating to about 3thou revs there is a knock then a shudder. took it to a mechanic and he put it on the computer and could not find any faults. maybe transmission? any help would be appreciated its an auto vn ss
wortus
It's not a miss under load? Take off your spark plug leads and check their resistance.
sootty grunter
wa
vn ss
hey man thanks for the reply... happens even when going down an incline though . may be torque converter after reading about an hours worth of threads last night
db_notso
diagnostic technician...
37
sunshine coast, qld
vt v6, mods(susp brakesetc...)
check if driveshaft bolts are loose
check trans mount ok not sagged or loose
check engine mounts not split or loose
check diff backlash ok (would do in other gears normally but)
check auto oil level ok and clean
if none of above do an auto service before replacing the box or getting diff checked by a professional
sootty grunter
wa
vn ss
thanks m8 had a quick look at all bolts and mounts seems fine, oil level is fine and like new clean.how much is a service usally and i pressumed the converter is its own part/ no .........spoke to a transmission guy yesterday and he said if its the converter it should be round 900...
db_notso
37
sunshine coast, qld
does the knock sound like its under you or behind you or infront of you?
exactly when noise occurs
eg driving staying at 90 then flat to floor accelerator and it knocks as gear changes
a service is cheap but oil is costly this is a last resort before replacing trans though!~
db_notso
37
sunshine coast, qld
then safe to assume its gearbox related
first i would check mounts VERY WELL if they are split or sagged the motor will twist the box and it hits the floor pan
often mistaken for internal gearbox fault
so
when the knock happens does the whole car shake like its affecting acceleration? or is it just a sound? EDI|T soz re-read title
a shudder means its a problem with the supply of power to the rear wheels
my gueass at that speed would be converter or low pressure of the fluid inside the box
either way i would "recomend" having the car driven by the gearbox mechanic so he can feel the fault occur
his knowledge and on hand feeling the fault happen will help him make an educated decision on wether or not its inside box or converter
he will MANUALLY go through the gears and try to make fault occur and also in DRIVE make fault occur
then he SHOULD be able to tell wether or not to rebuild the box or just put a new converter in
if it is converter when its cruising it would be in its highest gear when you accelerate there would be a longer than normal delay then it would drop down a gear
this is caused by the converter getting stuck this
is also common fault..
let us know how you go!~
basically i can give you more checks to do but without feeling the fault myself i might lead you the wrong way and we
would both end up very frustrated ;)
sootty grunter
wa
vn ss
somtimes its a faint knock then a shudder other times its hard knock doesnt happen any other time going through gears even up to 100 only happens when ur cruzing at 80-100 then acclerate
sootty grunter
wa
vn ss
yeah.. its affecting accleration for the period of the shudder then stops once its into gear
