VN suspension into early Commodore
Hangman
Aspiring Sociopath
Newcastle, home of Toranafest
WK Land Yacht
From what I've read the whole front end of a VN will bolt straight into a VB-VK, but what about the diff?
Is this a bolt in proposition?
What about springs and shocks, will the VN ones fit an early model?
I haven't played around with Commodores much so I don't know.
Cheers.
VK SL 3800
VK SL 5spd
VN-vp front end is a direct swap, rear end also is a bolt in job but diff is way wider and limits what wheels you can put on without having scrubbing problems. Rear springs fit dont know about the shocks i would imagine they would.
Jonno
Vic,
I got Vn springs in my vk
And last run of vk's changed from Sailsbury to Borg Warner..I think
So pretty sure Borg warers from vl is direct and Vn/vp are wider I velieve
VK SL 3800
VK SL 5spd
think VL's are wider too.
only the efi 6 VK ever came out with borg warner. everything else is salisbury.
My 85 carb has a borgwarner under the back, i think all 6's went to it circa start 85 production or "b" vk on the chassis no.
lowroozer
VB SLE
i have put a vn front end into my vb with no problem. i put a vl diff into the back and had to roll the gaurds as it was a tad wider.
hope this helps
