VN VP VG Air con issue
wbrent666
Paraburdoo
1991 VG 3.8L v6
My 1991 VG V6 has a problem with the air con direction changing from the face/upper vent setting to feet only under acceleration. Air blows cold just changes to the feet setting even when dial is set to face/upper vents. Not a major issue but it gets bloody hot up here in the Pilbara (especially now). Any tips or tricks of what to check for?
Thanks
losh1971
North Tas
VE Series I SS Ute
Its some sort of vacuum issue. Start by checking the y peice under the bonnet near the throttle body.
hi_ryder
Donating Member
Pascoe Vale South, MEL
Make sure the vac tubes behind the vent knobs havent come loose. Theres also a ball under the passenger side front bumper that stores vacuum. And the firewall vac hose has been mentioned, check there too.
