vn with ecotec v6
STL17
Whipit
townsville
Raptor charged vp v6 manual
Hey guy just got a quick question i just brought a vn with an auto ecotec v6 from a vx i was just wondering could i use the manual setup from my vr burnout wagon its got everything i need any help would be great cause my vn is nice and slow
soop
Banned
Smithton, Tasmania.
2003 SS Commodore Series II
So long as you get a bell housing to suit the Ecotec, there shouldnt be a problem.
(I'm no expert but no one answered.)
STL17
Whipit
townsville
I was told the t5 also came stock on a vs so it may fit
Chears for ya feedback
soop
Banned
Smithton, Tasmania.
It might have a different bell housing to the VR though. Because the VR had a buick motor.
I don't really know, just check it out before you go pulling **** apart.
STL17
Whipit
townsville
Yeh if i cant ill just sell manual wagon to buy mods for the vn then shift kit the auto
Immortality
Staff member
Sth Auck, NZ
HSV VS Senator, VT s2 Exec, VX Calais II L67
both the buick and ecotec use the same pattern bell housing so yes a T5 from a buick V6 will bolt straight up.
you would need to have the buick 8 bolt flywheel mirror balanced to the ecotec flex plate.
mechanically it is fairly straight forward. the biggest headache will be the electrical side. when the VN was converted to ecotec which ecu/pcm was used, or more importantly which auto trans has been used? if it is running on a VN 808 ecu then it's a fairly straight swap because the ecu doesn't control the auto trans, if the original ecotec ecu has been used then some wiring changes will be needed + a new tune to suit.
STL17
Whipit
townsville
Its the ecotec auto so i may aswell sell wagon and shift kit the auto thanks for ya help
