Mild 2 wild exhasust system for v6
Hi thomasr for a good sound on a budget remove the old muffler and put on a new sports one with original pipe work cost $100- $200 depending if stainless and brand. I highly recomend a lukey muffler. You could also do a cat bak system 2 1/2 system for under $300 with sports muffler. For ultimate performance go headers (pacemaker, Lukey, Genie, Difillipo, D & T or similar) set u bak around $400, 2 1/2 system, sports mufler, high flow cat and also dont for get the resinator for a smooth sound. A nice stainless Tip ( SS VT type is nice on vns vps) wouldn't be bad idea to finish off the job. Total system pipework, mufler, tip, extractors, resinator will set you bak around the $800 mark and u will notice the difference with hp increase and throttle response. Check out your exhasts place if your area, if u live in adelaide msg me bak and i can recomend some good places. Cheers subdue..
