VP V6 in-tank pump in VR SS BT1 Drop tank
VKCOMMO
Carpark Mechanic.....
Springwood, NSW
Hey
Can i put my V6 fuel pump (stock tank) into a VR SS BT1 drop tank and make it work?
Cause Ive been told that the V6 has one pump (high pressure) in tank and the V8 has a low pressure in tank and a high pressure inline
Or can i just use the in-tank VRSSBT1 pump and it will work fine?
Thanks
VKC
wortus
If you have the bigger fuel tank your gonna need to take the fuel pump assembly out and see if it is a low pressure priming pump or a high pressure pump. the high pressure pump will look just like the one in your original tank and the primer pumps are a bit shorter plus I dont think there is a pulsator.
You may be able to modify the bigger tanks pickup assembly to suit the high pressure pump out of your old tank instead of going to the trouble of fitting an external high pressure pump. If you can't figure out which pump is n it post some pictures of the pump and sender assembly from the larger tank.
VKCOMMO
Springwood, NSW
:air: informed me on CB that VP-VS had one high pressure pump, only VN had 2 pumps...
I took a look today and noticed that a few lines are a bit different, So ill post them up. Or worst comes to worst grab a gregories
mischa
Donating Member
Ruse, NSW
355 VN GRP A REP
Let us know jack, I wana ditch the 2 pump set up on my V8 and go the single.
vsl67
VS l67 statesman
removed due to trolls
VKCOMMO
Springwood, NSW
Will do.. Or you could come and do it, and learn then. LOL, Nah, ill take plenty of pics..
When I swapped My petrol tank over in my V6 VP for A Vs SS 80liter tank I just changed over some electricle connections and it ran fine with the V8 pump
Yeah, Im pretty sure VS have a different plug, VR are the same as VP..
Ill have the pics up soon, Just got home from work so im fugged...
EDIT:, OK, heres the pics...
This is on my current tank in the car, and stupidly i forgot drop tank pics, so ill get those in the morning...
See that pressed off there, the drop tank has another line there
But instead, doesnt have this line:
mischa
Donating Member
Ruse, NSW
355 VN GRP A REP
Pictures are blocked cause im at work but the return line on some cars goes into the internal fuel pump housing and some go into a welded on pipe up to the left and up a bit.
Ill take a look at the pics when i get home at 7.30, dam 12hr shifts.
VKCOMMO
Springwood, NSW
Yeah, It looks like on the drop tank it goes to the fuel pump and on the VP it goes to a pipe welded off to the side a bit...
Brett_jjj
Tamworth NSW
vs commodore
According to the VP gregorys manual,any VP built after 26th october 1992 has the fuel return line going back into the fuel tank through the fuel pump assembly instead of using a seperate return line back into the fuel tank, like the one in the pic above.
mischa
Donating Member
Ruse, NSW
355 VN GRP A REP
Yep, your options here are.
1. If the drop tank had a high presure pump in it (ie from a single pump set up) You can swap them stright over and run the return line to the pump housing and modify the connectors.
2. If its a low pressure pump you can replace it with a high pressure one if you can or source a new pump assemble that can come from any tank thats got the return line on the pump. Plus side of that is you might be able to get one with the same electrical connector then!
Im pretty sure the benifit of the return line on the pump is it gets returned directly into the swirl pot, not sure on the pipe mounted one if its got a line on he inside of the tank going to the swirl pot anyway.
BTW, when do you get your P's?
