VP V6 Knocking, goes away with belt off
AGRSSV8
VP SS, Cammed VN V6 daily
Hey ppl,
I've got a VP V6, has a knocking noise (like a midget inside the engine with a small hammer!) at idle and only slightly at higher revs.
BUT with the belt off it goes away, I'm thinking Harmonic balancer is shagged, there are a few cracks in the rubber around the internal circumference but no chunks of rubber gone.
Anyone had a similar fault or can confirm my educated guess?
cheers
FXST01
The Grey Man
Perth, WA
VP V6 Exec
Check that your power steering pulley's bolts are tight, but most likely the harmonic balancer.
calais_cruzin
Calais_Rattling....
Gold Coast
92 VP Calais 3.8
Id try spinning the other pulleys while the belt is off, just to eliminate that its not a bearing in say the alternator. But i think ur on the money with the HB.
Does the HB wobble?
AGRSSV8
cheers for the quick feedback guys, all good, well not really, The balancer rubber is loose on the crank, i can spin the rubber bit and not the crank. SOLVED, off to Repco in the morning ;P
Peace out
