scouser king
- May 6, 2009
- 674
- 2
- 18
- Age
- 35
- Location
- Rockingham, WA
- 06 VE SS
vp high performance v6 commodore
ITEM: vp high performance v6 commodore
YEAR: MARCH 93
SERIES: VP II
BADGE: EXECUTIVE SERIES II
ENGINE: V6 3.8LTR V6
TRANSMISSION: AUTO 4 SPEED
COLOUR: WHITE
EXTERIOR CONDITION: GOOD (SOME RUST A ROUND BACK WINDOW )
INTERIOR CONDITION: GOOD
TYRE CONDITION: 30% FOR BACK AND 50% FOR FRONT
ODOMETER: 236,505 FOR THE CAR AND 13,300 FOR THE ENGINE
SERVICE HISTORY: OIL CHANGE EVERY 5,000KM AND 98 FUEL ONLY USED
REGO OF CAR: THE CAR IS REGISTERED IN WA
REGO TILL: MARCH 2010
PLATES INCLUDED: YES
RWC: YES
PRICE: Negotiable or Make an offer $2,000
DELIVERY/PICK UP INFORMATION:CALL ME
PAYMENT OPTIONS: COD ONLY THANKS
CONTACT DETAILS: Email, PM, Phone or Other
[email protected]
(08)9524 8728 OR 0449751457
OTHER INFO:
is up for sale,due a bottom end issue.The car no longer runs and would need transport to move it.The car has had alot of work done to the motor,It can been fixed or sold for parts. i just dont have the time or money to keep going with it .I have spent well over 7k on the motor.The motor has only done a little over 13,000k sinc rebuild.
Engine specs are as:1 X FULLY RECONDITIONED LONG ENGINE .
REBORED AND HONED TO PERFORMANCE TOLERANCES.
CRANK GROUND AND LINISHED.BLOCK HOT TANKED,DECKED ,NEW WELSH PLUGS, BLUEPRINTED.
HEADS FULLY RECONDITIONED ,NEW VALVES ,BRONZE GUIDES,3 ANGLE VALVE GRIND, BACK CUT VALVES,BOWL PORTED AND FLOWED.
SUPPY AND FIT NEW CAM BEARINGS.
CAPA 1 X SET ACL PERFORMANCE PISTONS AND RINGS.9.5 :1 COMP
1 X SET ACL MAIN AND CONROD BEARINGS.
1 x Clive Roller 228 @50 Hydraulic Cam 3200 to 6700 rpm.
1 X SET OF PERFORMANCE VALVE SPRINGS AND RETAINERS .
2x Performance 70 mm throttle body c/o.
1x Performance chip to suit
1x Rollmaster Red timing chain and gears SINGLE ROW
12x Hydraulic lifters( NEW ! NOT RECO)
1 x FULL GASKET SET
1 X SET YELLA TERRA ROLLERS STD RATIO.
1 X 3500 STALL CONVERTER TO SUIT T700.
1 X TWIN THROTTLE BODY MANIFOLD
6 x 6x 36lb Injectors
A full 2 and half inch exusht system with pacemarker headers
The car also comes with a set 18inch mags ,pioneer cd deckworth $500
The twin throttle body worth $700 custom made
The car has a vp gts front and back bar with vr clubsport side skirts and clear tail lights
There are well over 3k worth of parts if you where to sell it.
ANY QUESTIONS ABOUT THE CAR JUST GIVE ME A CALL :thumbsup:
YEAR: MARCH 93
SERIES: VP II
COLOUR: WHITE
RWC: YES
[email protected]
OTHER INFO:
1 x FULL GASKET SET
