VR and VS Auto Transmissions
Brendo169
HSV Porn
WA
VS Senator
Ive got a full Series 2 VS Clubsport Wreck with 355 stroker and rebuilt auto with 3000rpm stally and a 3.9 diff
Is it possible to switch the whole drivetrain into a 215i VR Senator including the 355 stroker from the Clubsport(As its brand new). Will it be a straight swap?
Also if the autos are different can i swap the stall converters and use the existing VR senator box
Will the diff switch over no problem?
What about the computers. Can i use the vs computer in the VR senator or will i need to retune using the vr computer?
Krisp
perth
D22 St-r Navara
straight swap just put the drive line into yours
justbad4you
IF YOR NOT A HOLDEN
MELBOURNE S/E BAYSIDE
97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
sure can /////////
Brendo169
HSV Porn
WA
VS Senator
ok done some further research and its not as easy as you lot are suggesting
for starters the gearboxes are different. VR auto has 6 solenoids and VS has 7 as well as that the plugs are different
ecu's are different and the VS ecu wont run the VR or VS box without harness mods
pretty much the easiest way to do the whole thing is switch motors and also my diff and torque converter. Run ot off the VR ecu and auto box and get a retune to suit the stroker. then eventually get the vr box rebullt with a stage 2 kit
All up thats like 1500 for fitting, and another 800 for a retune. So near 2500 just to get it running. where as if i wait until a nice vs hsv comesa on the market everything will be a straight swap and a lot cheaper! i think ill wait!
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Swap the engine, gearbox, PCM (ECU) and loom. Easy.
crazywog
XR6 TURBO KING
MUZZA LAND
XR6 TURBO 380 kw of fun :)
the auto's in vs and onwards are electronic compared to the vr's and below.
Vee-ard
QuickVR95II 2010 Survivor
Bayswater, WA.
Foam Tuned VR 5.0l Ute
VR was the first of the electronic series. VP/VQ were the last of the cable kickdown series.
