V
VRBerlina05
Guest
Probably a dumb question, but I noticed some odd behaviour from my VR Commodore Berlina this afternoon. After a short highway stint(about 20 mins) I was sitting at traffic lights when suddenly the engine warning light came on and the engine started racing slightly. The digital fuel usage display start to show erratic figures(it usually shows 0 when sitting idle and in drive). I went to pull off the road to check it and it was very slow to kick into gear. I pulled up and stopped the motor and checked fluid levels, they all seemed fairly normal from what I could see, but the gearbox looked slightly high. When I restarted the car, the engine light was off again and it seemed to be running fine (for about 20 more minutes), when suddenly it seemed to drop in to neutral(or perhaps a heavy kickdown?) and I had to remove my foot from the accelerator to get the gears to engage again.
I get the feeling I may have put too much fluid in the gearbox, but I thought I'd ask here for some opinions in case I'm wrong. I did top it up a few days ago, but I only added about 150mls. I was also curious whether it has any safequards against slight overfills(ie could I have damaged it). I raised the car when I got home and there doesn't seem to be any leaks, so I'm hopefull I can just syphon the excess out of the filler tube and all will be rosey.
