Vr Calais horn problem
Chrisfatlmo
22
1994 VR Calais 3.8L
My 1994 vr Calais is having a horn problem did the basics checked my relay and fuse there fine alarm still works so horns them self are fine really don’t want to take the steering wheel apart if there is anything else that could be a easyier solution
Wozza
VR_GS commodore
brass pin wears out..its spring loaded and sits behind the wheel...have a look in the "how to" section for some suggestions on fixes
commodore665
expat Saffa
54
New Zealand via Cape Town
2005 SV6 & Alfa Romeo 156 V6
no need to post multiple threads on the same problem ,might have to remove the steering wheel cover to get to the horn switch itself .
Wozza
VR_GS commodore
forums pooched again..... ppl think message hasnt posted and keep hitting the post reply.....
woteva
NEED 4 SPEED
Adelaide S.A.
Multiple horn problem?
gtrboyy
vt ss & lc gtr
Usually brass button under steering wears down not enough contact to work properly.
Other issue is horn pad internals get hammered...works sporadically.
