Neigh
- May 12, 2023
- 8
- 0
- 1
- Age
- 29
- Location
- Nsw
- Vr commodore
Hey guys I have a 1993 vr commodore berlina manual with v6 Buick it’s been giving me the biggest headache every lol
so I was driving and al of a sudden it just lose power and stall I would start it back up drive for 2 minutes and it would happen again I ended up getting it home and straight away changed the CAS witch is quite a common problem but unfortunately for me it didn’t fix it so then I changed the DFI plate still no change after turning it on in 10 minutes it just cuts out ! So next step was to change the fuel pump even though the one in there was purchased less then a year ago and while I was at it changed the fuel filter I started it and it and it ran for 15 minutes in the driveway so I took it up to the servo and put fuel in it I was like bingo I have solved the problem but just my luck nope on the way home it did it again I sat on the side of the road and waited 15 minutes for everything to cool down and started her back up and kept losing power and staling all the way home again so yesterday a mate came over he told me it had to be the CAS and the one that I purchased was probably faulty/already dead so I got another CAS and of course it wasn’t the proplem so while I was at it I changed the oil pressure switch so yer no luck and yes I have changed all the fusses and relays has anyone ever had this problem I keep reading forums and anything that sounds similar I read and change that part but now I’m out of ideas please help thankyou sorry for the long rant and if it doesn’t make sense I apologise I’m a bit dyslexic and p.s sometimes the idle is high
