should be pretty much the same as a vs S1, in that case ;
remove red central locing tab unhook locing wire from lock, remove lock (keep together ) then remove 3 screws holding your inside door handle/rest, remove window wiper handle (if non electric) down the bottom of door trim are some more screws remove thise as well check for any more screws that may be holding the door trim on. if all clear gendly pull door trim from door should "pop" out and then push it upwards towards the roof . then you should have access to the speakers. if your planning on putting 6.5" speakers in the door you will have to cut about 5mm off the circumfrence of the speaker pod mount thing (black thing)
I hope thats right, as thats how i did it on my vs.
Cheers,
