VR pully nuts loosing when engine runing
sekiflying
Runcorn, Brisbane
VR
I found out the the 4 nuts on the pully become loosing when I the engine running.
I am pretty sure I tight it up normally.
I think I bend a bit of the seal which in front of the pump(Because I had trouble to put it into pump)
Is the loosing because of the front seal? will I fix it if I replace a new pump?
IBLOWN
44
VS V6 TT/'13 VF Senator/'11 WM CapriceV/Hayabusa
If your nuts are loosing you must not have tight up properly. They cant come loosing.
If you bend a bit of the seal then pump will leak. Better change seal so not leak.
Nuts loosing wouldnt be from bend seal. Although if whole pump on angle then maybe nuts loosing.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
:rofl2: What he ^^^ said.
Immortality
Staff member
Sth Auck, NZ
Couldn't have said it better ^^^^^ :rofl:
No learnd nough :hmmm:
