vr ss heats up fast then cuts out runs real hot
U mad bro?
35
Australia
vr ss
hey
the vr ss I got heats up fast then cuts out.
No oil leaks or any thing has 5.7 lt injector small cam but would that make it run hot?
Like over half way tempo wants to stall don't know what the problem is.
Book Into merchanic but That said that cant find what it wrong
Checked for blocks found nothing
twin thermo's fans they don't keep it cool
does't have a crack head or anything
does need a tune would that maybe fix it?
cheers
p.s The guy who i got it off said it had a different thermo stat and the twin fans that why the engine light is all way on
BlackVXGTS
Melbourne, SE
First step would be to display your error codes to see why the engine light is "all way" (sic) on. Use the link below. Assuming the fans are starting and running OK:
1. Make sure the thermos have a shroud and that the shroud is sealed properly to the radiator.
2. Check the thermostat to make sure it isn't blocked or faulty. I'd be installing a standard thermostat.
3. Replace the water pump.
4. Change your mechanic.
5. Consider using spell check. :)
https://forums.justcommodores.com.au/threads/checking-error-codes-vr-vs-revised.22307
U mad bro?
35
Australia
vr ss
thanks for the info will replace all that stuff.
Spelling was bad as I was in a rush to get the car !!!!!!!!!!!!!!!!!!!!!!!!!!11
