Jaso74
- Dec 17, 2023
- 25
- 10
- 3
- Age
- 49
- Location
- Traralgon Victoria
- VR commodore Ute 5.0
I've just got my self a VR ute that has had a 5 litre conversion and it's not running well. I have found various issues so far but just doing the general lookover before I get to far into one thing to fix .
So far I've found a vac leak near 4/6 cylinders on inlet manifold around injectors area, could be injector seals or inlet gasket, yet to confirm.
It has a Crow 4761 cam fitted and it's probably way over kill as I'm guessing engine is other wise stock except from cam and pacemakers but I could be wrong as I don't have very good to no history to go on, but that being said it should run better than it does as it seems to be fair dinkum pouring fuel in engine and believe several faults may be present.
I'm far from finished diagnosis of poor running but this one has me a little stumped as I can't find any info so thought some one here may know.
The ecu original sticker removed and a paper sticker attached with the words " Delco Injection Control Equipment" printed on it with memcal configuration listed as being 1 bar , no knock sensor , a serial number and also a "G" hand written in the corner. I will attach pic too . Also there is a serial type port fitted to the side of the housing which I'm assuming is for tuning via pc/laptop .
I did try a standard VS auto ecu as I had one here from a previous ute I had years ago and it doesn't run at all with it, mind you I'm totally not sure if it should or not, pretty sure my old one was series3 5 litre so I think that is an issue perhaps in memcal config ?
Anyway I did a quick search and found nothing on this mystery ecu .
Just trying to figure out if there could be an issue here as well as other components before I go to far?
Cheers for any info at all
