flexcenlexcen
- Jul 18, 2014
- 12
- 0
- 0
- Location
- adelaide
- vr v6 auto acclaim and vn lexcen v6 manual
mates vr exec v6 auto wagon is dying off under load idles fine and free revs fine in neutral and park but dies off at around 3000rpm in any gear with the revs dropping back to a rough idle popping misfiring and carrying on ect
ive done a fairly in depth search of jcs and havent found anything i have not already known or tried
has new alt and battery
changed or replaced all the usual suspects
fuel pump
fuel filter
coil pacs
dfi module
leads
plugs
injectors
map sensor
throttle body
o2 sensor
more fuel just in case the fuel gauge was lying
fuel pressure reg
cat convertor
temp sensor
have not done the cas cause it makes no difference if the motor is stone cold or hot and it cant be driven far enough
checked fault codes got 12 22 and 83
12 is ok clearly its not other wise i would still be driving it
22 is tps going to try a third throttle body on the weekend just in case its a second faulty tps
and 83 is TCC PWM Solenoid Fault but i cant find anything on here or else where that matches the problem that has anything to do with code 83 so im thinking that its a totally unrelated problem for another day
also has a broken lh engine mount another problem for another day
just wondering if any one else has had the same problem or knows of something ive missed apart from the obvious fix to all problems by washing the whole car with liquid hydrocarbons and drying it with a match
fuel pump
fuel filter
coil pacs
dfi module
leads
plugs
injectors
map sensor
throttle body
o2 sensor
fuel pressure reg
cat convertor
temp sensor
