clubbie93
My 12/93 V8 Clubsport auto has suddenly decided not to shift up properly. It will start off in 1st gear and won't change to second until the engine is doing something like 4,000 rpm and sometimes won't shift up at all. It is also slow to shift up in other gears if I manage to get that far. This has happened quite suddenly and it has been perfect until then.
When I shift from neutral to Drive it gives a solid jerk forward which is not normal - usually quite sweet and smooth.
I have dropped the oil pan off the trans and replaced the fluid filter and a new belly full of Dexron III but the problem is still there. On the very odd occasion it will suddenly decide to go back to normal but then it will play up again.
Has anyone seen this kind of problem before ? It seems to me that the electronic control either inside or outside the trans is getting its signals screwed up.
