VS 5L T5 conversion
Wombles
Cars cost too much.
I know... Another one...
But I need help.
My reverse lights will need go on when reverse is selected. Plus my interior light will not turn off.
I have used the manual wiring loom and computer.
Have also plugged the park/neutral switch in.
Any ideas?
Clint_G
05 VZ SS
If you have used the maual loom then the reverse light switch wire should just hook up to the switch itself and work from there. Unless the switch is faulty. Interior light is a wierd one. You havent got a blown fuse somehwere maybe.
Wombles
Cars cost too much.
I have tryed both ways with the reverse lights but it wont work.
May have a faulty switch then..
Ill check fuses..
Clint_G
05 VZ SS
Have you tried bridging the wires over to see if the lights come on. That would then also tell if its the switch or not.
wamboin23
Donating Member w/ Boost
Wamboin, NSW
VS Calais - Cooled L67 + T56 | VR Acclaim V6
what do you mean you plugged the park/neutral switch in? have you got the small adaptor that goes between power button wiring and inhibitor switch wiring?
with the interior light, make sure you haven't bumped the dash dimmer switch to the up position.
Wombles
Cars cost too much.
No. I do not have that adaptor.
That is a good point Wamboin.
Park/neutral switch. The inhibitor switch is what I meant.
wamboin23
Wamboin, NSW
that adaptor is where the reverse light wiring in the manual harness connects to the reverse light wiring of the vehicle.
pretty sure it is blue wire on the power button wiring, to the green wire on inhibitor switch. then join grey and grey blue.
Wombles
Cars cost too much.
You got the interior light correct.
Wombles
Cars cost too much.
Wamboin, you genius. Made my own adaptor up and it all works.
Only thing that will annoy me is the PWR light in the dash. A bulb removal will fix that!
Clint_G
05 VZ SS
Good to here its all working. Was it hard to make up the adaptor.
