Jeremyjames
- Jun 15, 2016
- 6
- 0
- 0
- Location
- Central coast
- 98 series3 vs statesman
All right this will be my first post here , I recently came into possession of a series 3 vs statesman , 304 roller type engine. No problems for a few weeks, serviced it with oil , oil filter , air filter , coolant. No dramas , doesn't heat , doesn't use anything at all, great on fuel. So this morning I decided to degrease the back side of the engine where it had a very minor tapper cover leak, rinsed it off lightly ( in hind sight a shite idea) and it wouldn't start. So I chucked the workshop heater under the bonnet and it came to life in about ten mins of heating/drying. Drove about 1-2kms, sounded like a slight pop or misfire and died on the spot. That was at 10 this morning about 8 hours ago. Turns over but not firing, wd 40 the ferk outa the electrical areas , ran the battery and a jump start pack flat trying to start it. :/ havnt pulled the dizzy cap ( although I'm assuming there water in it ) or coil yet due to the impossible location and it being on the side of the road away from tools. Just wondering if anyone knows if the existing coil wiring ( + -) will reach to a new coil mounted in an easy to access area, in the strut post or similar ? Aaaaand I have a smaller fuse / relay box in front of the main fuse box that contains 4 fuses/ relays, the two pink ones look to be corroded / blackened on the small conductive piece held right in the middle of the fuse. Is that blown or just old ? Can anyone tell me what they are for? It's my daily driver and I have 3 kids under 6 I gotta transport and shop for. Thanks in advance for any advice , I really appreciate the effort.
