disconnect heater control rod next to where your left ankle would sit on drivers side , little
white clip on swing arm
drop panel below steering column ,3 clips twist 90 degrees
3 screws down driver side of dash facia
drop glove box 1 clip in box at rear right , slide clip out towards passenger side
3 screws down passenger side of dash facia
remove ashtray
remove panel around shifter clipped in only and slide back
3 screws along bottom of center facia panel
unclip facia panel carefully
Unplug the LED for immobiliser (this sux)
4 screw hold dash facia and 1 in AC controls
2 plugs in rear of AC controls + 1 hose cluster
undo 2 Large chrome screws going straight down and console will drop
remove dash facia
2 screws holding deck in
Orange = constant 12V
yellow = accesories
Black = earth
Brown/white = illumination
yellow/red = elec aerial
dark green & light green = front right (DG-)
tan & grey = front left (G-)
dark/black & blue red = rear right (DB-)
brown/black & yellow/blue = rear left (YB-)
There is 3 screws holding the brackets to the deck , if you drill a new hole
between the 2 screws that are towards the front of the bracket it will line
up with most after market decks and will screw straight in and look stock again.
