Vs brake rotors on a vy??
pedroc
VE SS UTE
Hi all,
Just a quick one, wondering if i can take rotors from a standard VS Commodore
and put them on a VY Commodore??
Any help much appreciated.
Thanks in advance
Pedro
jas98
34
maryborough QLD
vs commodore V6 S2 and a BA XR6T
Hi all,
Thanks in advance
Pedro
simple awnser is NO
they would fit onto the hub but the caliper will not bolt on as the VS disk is smaller and the vy is much larger
im guessing you have a spare set of vs ones lying around??
pedroc
VE SS UTE
Thanks for the quick responce jas. Yeah i got a VS off a mate in pretty **** nick
but the pads and rotors are nearly new! So are you saying i can just do a switcheroo
with the pads and rotors? VY to VS and VS to VY??
Also will this reduce my braking performance on my VY? If so im prob best just buying new
VY rotors??
Pedro
social
Ute Finatic
South Aus
2012 VE Thunder
He said no, as I would state the same info, non transferable.
Surfwagon
Sydney/NSW
AMG Mercedes C63 Wagon
Jas98 is right and wrong.
The main answer is still NO but the VS rotor wont even fit on the hub as the VT-VZ hub is 71.5mm and the VR-VS hub is only 70mm.
When retrofitting VT-VZ discs on to VR-VS you need hub rings (look like thin egg rings).
jas98
34
maryborough QLD
i didnt know that haha
nothing a big hammer wouldnt fix though lol
Cheap6
VP Exec
Just swap the VS hubs across - problem solved! (I have seen it done. Someone with a VR or VS rented a VT and swapped everything across for a brake conversion at the cost of a day's car rental fee. No way to tell which renter it was by the time it was picked up on.)
