Bob is correct, as usual.
Just went and checked mine, because I couldn't remember.
Hold "amb" and turn the ignition on, then press "off". Release buttons. That gets you to the screen test. Press "amb" again and that takes you into the diagnostic mode. "Up" and "Down" buttons take you through the diagnostics, along with "amb", but I haven't got the "addresses" at the moment.
Thx for the feedback guys,
I followed your steps above and came up with the following,
You can have the ignition on and then press "AMP" followed by the "Off" as it also. This also worked for me.
Once in the diagnostic check it will display a tick that all is fine. It then displayed 55 degrees.
1/ I then pressed "AUTO" and number "1" was displayed in the bottom left corner. The unit then displayed 55 degrees.
2/ Then by pressing the up button I believe it lets you check the individual sensors. But I don't know what each number represents.
After the initial pressing of the "UP" button, number "1" was displayed indicating "55" degrees.
3/ Pushing the "Up" button again a number "2" was displayed indicating "28" degrees.
4/ Pushing the "Up" button again the numbers "1" & "2" where displayed indicating "28" degrees.
5/ Pushing the "Up" button again a number "3" indicating 33 degrees.
6/ Pushing the "Up" button again the numbers "1" & "3" where displayed indicating "55" degrees.
7/ Pushing the "Up" button again the numbers "2" & "3" where displayed. It now shows only a numerical reading of "0"
8/ Pushing the "Up" button again the numbers "1" "2" & "3" where displayed. It now shows only a numerical reading of "0"
9/ Pushing the "Up" button again the letter "A" was shown indicating "73".
What each of these readings are for I have no idea. I believe the first four readings are sensor readings. But which sensors? :bang:
The are also a few other checks possible also. But who knows what they are?
I then installed my OLD VR unit and the reading where identical except the VR unit is stuck on an "AMB" reading of "55" before and after starting the car.
The newer unit (VS) is stamped 1998 and actually runs down to "16" degrees where's the VR unit will only go as low as "18" degrees. The VS unit will display the correct "AMB" temp when the reds are on and 9 out 10 times **** itself after starting the car and displayed either "55" or -"30" degrees. ON the odd start a cross is displayed on this unit whilst kicking the car over.
I think both units are faulty :cry: :ranting: :cry: :ranting: :bang: :rip:
Struggo
