VS Commodore not starting
Tucker nz
35
Dunedin
Vs commodores
Hello all my vs is not starting I have changed the battery change the starter motor all it does is click can anyone tell me what could be wrong
immortality
Staff member
Sth Auck, NZ
Check, clean and tighten all the battery and main cable connects including earths. Failing that, check the relay (try swapping it with another one like the horn or high beam that doesn't get a lot of use).
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
Is your key in good condition
Utel67
Tasmania
Vs s3 ute
See if it starts by bridge the starter relay
Tucker nz
35
Dunedin
Vs commodores
Tryed all that succulent could be the starter motor not connecting
51
Melbourne - Frankston
Vs V8 Ute
Howdy,
I had a similar issue. I had to change the coil and then the BCM. Car would crank but not start. Hope that helps?
Cheers and Beers,
Tucker nz
35
Dunedin
Vs commodores
Thanks all car is back going but had to replace something just to get it running even better as it had a 4 inch crack in it
