VS Commodore transmission breather line hose size?
Holden chik
41
Waterford Qld
VS SS S2
VS ute trans dipstick popped out spraying oil all over rocker covers etc. Wondering what size the trans line breather hose is? Planning to replace if blocked up.
krusing
Melbourne, Bayside
Doesnt the Breather pipe have like a small plastic filter on the top of it ?
Sort of looks like a check valve.
Some Breather pipes had a hook at the top so moister and/or water wouldn't run down in the trans
Holden chik
41
Waterford Qld
VS SS S2
Probably 3/16 or 1/4" from memory.
Pull it off, check its not blocked, and then you have it in hand to match up if replacement is required.
Yeah thanks was just hoping to be able to buy hose during the day before having to jack it up & do the job. But thankyou.
losh1971
North Tas
VE Series I SS Ute
Can always pull it off and blow it out with compressed air.
Fu Manchu
WA.
Agreed.
Or degreaser down the line to loosen it up. Then the garden hose on high pressure, and/or air.
With the hose off the transmission of course.
  • Like
Reactions: Lex
Immortality
Staff member
Sth Auck, NZ
Was just in the garage measuring up something else and remembered I had a 4l60e sitting down the back somewhere.
Hopefully that helps someone.
Fairly sure 4.8mm equates to 3/16"
