VS Diff question
Fred 96
Wellington, NZ
VS HSV Clubsport
Hi there all,
Apart from putting all new bearings in it, what else should I get replaced??
Thanks.
EDGE3
NEWCASTLE
1997 VS COMMODORE,1996 GTS-R COMMODORE
It depends on how bad it is working,you might need to check the ring and pinion,axle,if the gearsets are worn they will need relapping.
Cpt Awesome
perth wa
04 S II HBD VY SS , 04 VY S II Executive
get a bigger crown wheel. Like 3.45 or 3.9
Pub247
Melbourne S.E.
Ford Fairmont
Its not a bigger crown wheel if you did you'd get one from say a Bw80 diff (vt s2 onwards) it wouldnt fit because its bigger.
You actually need a different ratio crownwheel and matching pinion.
As for OP question worth getting your LSD center rebuilt if its needed
Fred 96
Wellington, NZ
VS HSV Clubsport
Update :
Have just sourced a new LSD center for it, so thats going in it. So what else should I get done??
Thanks.
