VS Error Codes - 23,32,44,63,64 and 76
RedGoesFaster97VS
Perth,WA
96 VS Executive S II
Hey guys and gals, I'm new to the whole DIY car stuff, i mastered the art of checking error codes (or so i hope), these are the error codes i got
23 - Mass Air Temp Sensor (High Voltage)
32 - Manifold Air Flow Sensor
44 - RH Oxygen Sensor Lean
63 - LH Oxygen Sensor No Signal
64 - LH Oxygen Sensor Lean
76 - Air/Fuel Ratio Variation Between L and R Banks
I've had a look around on JC and other sites and have found a little bit out, but nothing that i could really use, but to me its all sounds like the same sort of problems rather than being 6 completely seperate issues.
If someone could shed some light on this or let me know where i can look to help fix this that would be great. If not post on here then feel free to email me at [email protected]. My car is on ULP/LPG if that helps. Thanks heaps in advance :bow:
PS If anyone knows where i can get hold of a Gregorys Manual or something similar in a torrent etc that would be great =)
pjdm1980
Shut up Jr I'm thinkin!
Geelong, Victoria
E1 GTS BUILD NO# 007, GQ Patrol.
These 4 are the same Type of problem
44 - RH Oxygen Sensor Lean (Change O2 sensor)
When the O2 sensor is stuffed they run lean and the computer dumps MAX fuel so replace the sensor to correct it.
63 - LH Oxygen Sensor No Signal (Same Prob)
64 - LH Oxygen Sensor Lean (Same Prob)
76 - Air/Fuel Ratio Variation Between L and R Banks (Because the O2 sensors are stuffed)
RedGoesFaster97VS
Perth,WA
Thanks, ill look at getting them replaced, what about the other error codes 23 and 32??
Manifold Air Flow Sensor and Mass Air Temp Sensor (high voltage)
pjdm1980
Geelong, Victoria
23 - Mass Air Temp Sensor (High Voltage). (Not 100% sure but could be the one one the air box maybe call an auto elec)
32 - Manifold Air Flow Sensor (i pretty sure thats the one behind the air box)
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
check the fuses i think all the items you mention run off the same fuse
RedGoesFaster97VS
Perth,WA
Thanks guys, ill check the fuses, if only cars were that simple.
ephect
Donating Member
VS Acclaim V6
RedGoesFaster97VS
Perth,WA
Thanks, ive had nothing but trouble with that LPG since i bought the car, runs like ablsolute cr** but im having a tank test and service done on the LPG soon and i will replace the O2 sensors and see how i go.
ephect
Donating Member
VS Acclaim V6
before you get everything serviced, clear your codes to see if any new ones pop up a week later
