Vs getrag to vl
BVL87
47
cairns
VL 5L
is it possible for a vs getrag 5speed v8 box to bolt up to a VL v8. is the crossmember for the box from the vs going to fit in the vl and also the tailshaft will the front half bolt to my rear half. also the speedo cable from the vs plug in and work on my VL cluster
nasty1
adelaide
vy2 clubsport
Front of 5 speed bolts to rear of your Vl tail shaft. Duno if box adapts to Vl engine.cross member needs the holes re drilled.and I here alot of messing around with speedo etc to work
BVL87
47
cairns
VL 5L
so tailshaft is all good then will simply bolt up???? i have a vk diff in my vl so will need to keep the rear part of the shaft as uni's are different. the speedo i have sorted putting in a after market electric one as there no cable in the getrag box. should the bellhouseing just bolt up as the block are the same (308/304 block's) just the top end in different as vs is injected and mine's carbi.
nasty1
adelaide
vy2 clubsport
For some reason I think the bellhousing I's difrent
