Ryan vs ute
- Mar 12, 2018
- 1
- 0
- 1
- Age
- 30
- Location
- Agnes water
- Vs ute
Hi guys
Having trouble sorting out idle. I have to keep my foot slightly on the revs when I come to a stop otherwise after 20 seconds it will stall. If I pull the clutch in and let the car roll, it won't stall when I'm moving. The revs are a bit sticky around 1.5 rpm when clutch is pulled in and it stalls when they settle to normal idle rpm.this is when it's at normal operating temp.
when it's cold on first start up it will idle for a few minutes but stalls as it begins to warm up. . Have swapped tps ,iac and maf sensor cleaned throttle body checked for vaccum leaks. . Car runs fine other wise. Any ideas appreciated cheers legends.
