vs intake manifold on vn
hakhawk
smooth moderator
Staff member
hey guys, just a thought, is it possible to drop a vs v6 intake manifold onto my vn v6 block? it looks a nicer setup, and looks heaps easier to work with. do you reckon it would be worth doing? and how would i go with the front of the block, ie alternator, belts, etc if i want the cover on it aswell? just an idea.
Cheap6
VP Exec
No, sorry. Heads were changed on VS- and the valves are in a different order, hence the ports are too, regardless of any possible mismatch in geometry.
hakhawk
smooth moderator
Staff member
oh well, thanks for confirmation though.
HICOMPVN
Wanting That Lil Bit More
Seaford, Vic
1995 VR SII Commodore
Post revival...
so does that mean if you ran VS head's on a VN as well as VS intake it could work.???
ephect
Donating Member
VS Acclaim V6
Wow! Holy thread revival batman!
From memory talking to hak, the cam lob spacing are different.
Immortality
Staff member
Sth Auck, NZ
Post revival...
The heads do bolt on but then you still have the issue that the Ecotec engine uses a shorter deck height than the Buick so the manifold still won't fit and then you have to contend with the cam issue mentioned.
I have seen a picture somewhere of Ecotec heads on a Buick block and some of the push rods did seem to run at a bit of an angle. You would also need a custom cam to suit the different In./Ex. port arrangement.
_R_J_K_
Zenki S14
Pretty sure the water jackets are different too.
Jxfwsf
Aus
commodore
