VS leaking water behind motor
Frog201
hi all
I've notice that my vs has started leaking water behind the motor somewhere it's about 3 drips every time you park the car. I've checked all the horse's on the top of the motor but i can't pin point where it's coming from.
Does anyone have a idea What it is
aussie4life
Keep It Simple Stupid
South Australia
2010 VE International 3.0L
All the Horse's? lol. where abouts in the middle of the car are you talking? if its more towards the trans it could be your heater core
justbad4you
IF YOR NOT A HOLDEN
MELBOURNE S/E BAYSIDE
97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
justbad4you
IF YOR NOT A HOLDEN
he saying behind the motor.......
ephect
Donating Member
VS Acclaim V6
As said prolly heater core, could be heater hoses near the firewall, heater tap may be damaged, I'll have to look for signs of water runs, look under the car about the trans to see any water resting on it or running down the exhaust pipes
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
If it's not the A/C and it's leaking from between the motor and the bellhousing it probably will be the rear welch plug - they rust out eventually and it's engine out to fix....However a can of "stop Leak" will make it last a year or so generally.
