oldmate
- Jul 17, 2006
- 21
- 0
- 0
- vs executive
G'day everyone, i think i might have a problem with the indicator arm. when i use the right hand indicator, it wont automatically turn off. Turning left is fine. Also, if driving with the lights on, the high beams will come on if i use the right indicator, but the stalk will still be in the normal position. I have to turn the high beams to the on position then off to put it back to standard light. Again, no problem when using left indicator. There are some one off occasions when it works fine.
Does the indicator arm need to be replaced, or is there something that can be done by pulling it all apart??
