VS rough idle
Pickled
Melbourne, VIC
Barina
G'day, so my VS shakes and vibrates a little in park, when in drive and stopped (at the lights etc) it will idle pretty rough, it will go as low as 400-500rpm. It's on dual fuel also.
Any suggestions on what this could be?
Shambo
In a House
Series III CV8 & VE 3.0 Omega
I had a similar problem with mine and it tumed out to be the spark plug leads.
If you have a multi meter that does ohms it wouldnt hurt to check them. Cylinders 1,3 & 5 should have a resistance less than 10,000 ohms and 2,4&6 should be less than 17,000 ohms.
Mine was running terrible at idle and this was all it was. It also wouldnt hurt to check your spark plugs while your at it.
EDGE3
NEWCASTLE
1997 VS COMMODORE,1996 GTS-R COMMODORE
I agree with Shambo check the leads my number 2 lead went also and the same thing happened,and you cant adjust the idle on a vs because it is factory set.
White Tiger
Semper Fidelis
Murray Bridge SA
HBD VY Berlina, RB30 GQ Patrol
i got the same problem and am hoping its just leads/plugs cause their easy and i know they need doing
and it doesn't bog down like if a coil was dead/dying
richie401
melboure
Vz SS 6LT
yeh my vs l67 was doing the same, change the leads and plugs hasent happen since, gotta luv when it a simple fix :)
