VS sedan speakers
T
tja
Guest
does anyone know how to remove the rear speakers out of a vs sedan. any advice would be helpful. thanx
T
Truk22
Guest
If you are talking about the factory metal pods that are in there, and are spot welded to the frame then there are 2 options, drill the spot welds out or knock them apart with a chisel, i suggest the chisel, its quick effective and the parcel tray covers all boo boos.
Tasmaniak
Not a valid input....
41
S.E. Melbourne
www.ranjinstallations.com.au
As a side note, to remove the parcel shelf, you first need to remove the back seat. A quick simple 5 minute job. Find the catches at eithe end. Lift up and the back seat comes away, then whip out the back rest which is held in by three bolts from memory.
