VS Speed Alert backlight
timmo666
VE SS-V, V8, 6 Speed Manual
VS Speed Alert backlight:
the speed alert works fine, the backlight is just out.
is this just a globe that can be replaced or possibly a wire loose?
thanks guys.
VrWagz1
The Wagon on Wheels..
wollongong
www.wagzhome.justcommodores.com.au
VE SSV MY09 Auto Wagon
probably the globe, i think they are always on as they are not hooked up to the light switch so they are fairly common to blow.
seraphic06
Woodgrain Nut
Adelaide, SA
VZ Berlina Wagon, VS Caprice Series II 5.0
Yep it is a globe and they cost about $17.00 from GMH. Go to a wrecker and see if you can scrounge one there. The globes inside the power antenna switches are exactly the same (and air con, rear wiper in earlier models).
timmo666
how hard is it to change one of these globes?
are they mounted in the power clip or inserted to the speed alert itself?
Sort of new to me, fiddling behind the upper dash, don't want to break anything lol.
VS Omega
VS Commodore Omega
On topic, any way to make it blue?
88GreenVN
Next Exit Left
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
Get the small globe condom from the speed shop, you can get the 4 main colours, green, red, blue and yellow. Also the make them for T4 neo wedge and T10's (dash light size).
timmo666
do you have to get one of these globes from a wrecker or a holden dealer?
or can you buy a specific globe that will fit from a car specialist shop such as "Repco"?
dylanfh
Sydney,nsw
91 VP 5.0 V8
Repco should have one,thats where i got mine
To replace just take of the plastic dash surround and unplug and take out the speed alert.
You might need long nose pliers to get the globe out,ive put a post on here somewhere with a pic attached if you feel like searching.
I cant quite remember but i think the globe was about $4.00.
Verynice
Band
VS Caprice 5L
i noticed my backlight started blinking ion and off so the globe was on its way out. So anyway i ripped it out and squeezed a bright blue LED in there with a resistor and it looks smick! it lights up the screen and buttons blue. Id say the blue sleeve over a 12v globe wouldn't have as much effect as the LED
Also while i was at it i replaced the orange/amber overspeed indicator LED with a blue LED
Looks awesome and i recommend you doing it. If need pics just PM or reply
Nato B
95' VS Vacationer
Kadina, SA
VS Vacationer
Yeah man chuck up some pics.. wanna see if its worth me doin this too scince i have to replace globe anyway.. :)
