Just need to find a shop that still has Rolling resistant torque guages to reset the pinion preload afterwards. An hour may be a bit under quoting. Id put it at about $220-260 parts and labour as theirs a good 15 minutes bringing a car in setting it up on the hoist. Then drop oil, tail shaft and centre bearing hoop, remove pinion nut and front flange then change the seal out re assemble and re fill . Most shops are $110 an hour id estimate 1.5 hrs + seal and oil.
