vs supercharge
Nathan72
vs 3.8
hey guys would the m90 supercharger fit straight on to the vs motor and if so wat mods or engine upgrades would i need if i had got one. thanks
shaggerz
Victoria Point, Brisbane
2004 VY2 SV8 A4
Absolutely not. pretty much only the block is the same. You would need new heads, new intake manifold, fuel injectors, fuel pump and some other stuff. Also even if you do make the conversion, it will be a weaker engine because the rotating assembly is stronger in the L67 as well.
It is usually better to either do a complete engine swap (engine, loom, computer) or sell your car and buy one with the L67 already in it. I did the latter :D
Nathan72
vs 3.8
oh ok kool thanks do u now a good supercharger that will fit straight on or bolt on
shaggerz
2004 VY2 SV8 A4
Depends on your target and your budget. If you just want a little extra power, a kit from Castelmaine Rod Shop will do you nicely. It runs 3psi of boost and can be switched on and off. A 6psi pulley is also available but you have to forego the ability to switch the boost on and off.
If you want real power, a tough streeter... expect to spend $4000 rebuilding the engine to handle the power, or drop in a stroker motor for roughly the same money. You'll then need to spend another $4000, possibly more, on the supercharger.
On the other hand $4000 will get you a complete L67 conversion (not including labour)
sircruisealotVS
39
South Brisbane
VZ LS1 Calais
maybe you'd be interested in a raptor kit mate, i personally confess i dont know much about forced induction, but they're supposed to be alright. have a look in the raptor section of the forum.
Immortality
Staff member
Sth Auck, NZ
yeah, the raptor kit would be the way to go. if you look further down they have there own section. they have been posting some good results there. definitly a good alternative to the l67 setup
Charg'd
in a ford
ford
alot of superchargers will bolt on, but it depends what your after, if you want big power, it'll cost you big $, check out the Raptor superchargers, ive heard good feedback about them, & unlike someone else, they are always there to help & answer questions
Tadgh
itsjustasix
blown VS executive SII, 5sp
Raptor not too shabby
Yeah, I threw a raptor kit on my VS and i must say that for the $ value i was pleasently suprised with the results. It does take a little bit for the boost to build up, but it does produce nicely above 4000rpm. It goes well from standing starts and beats 5L V8's with ease, It also beats by both my mates r32 and r33 stock skyline GTST's. Match it with a 5sp man and you will have hours of fun, especially in the wet. Could easily be your cheapest and easiest option, but that is just from my experience, there could be better out there for the same price.
Hammers
Hammers
VS Executive S2 Auto
hey shaggerz how much u looking at for the castlemaine rod shop job????
shaggerz
2004 VY2 SV8 A4
http://www.rodshop.com.au/
that is their web site. $1950 + delivery by the looks. Remember that you get what you pay for however...
