Superjet0701
- Dec 30, 2008
- 6
- 0
- 0
- VS 111 V8 Ute and VS 11 V6 Calais
Hi to all,
I need some help with the thermo fan on my VS 11 V6 Calais, over the last 3-4 months I have replaced the following, water pump,
thermostat, temp sender, flushed and replaced coolant and bled cooling system correctly, all has been going well untill a few nights
ago when I was sitting in Maccas drive thru i had the high temp alarm beep at me only to realise that the temp had gone through the roof!!!
I pulled over to find that my thermo fan was not working unless I had the air cond turned on, in which then the temp runs normal. So the next day I went and purchased a new
coolant temp sensor and replaced it but the thermo fan is still not working without the air cond turned on.
I have searched all commodore forums for an answer to why this would happen all of the sudden, but none of them have an exact answer to my problem, so anyone that can help
would be greatly appreciated!!!
