VS Thermo fans not working
willo2
55
goondiwindi
vs commodore
Hi
I have a vs ute. It overheated today. The thermo fans are not working. When you switch the a/c on they don’t work. Also not working at high temp. Any ideas. Have read some old posts but none mention this problem.
NORTI
Radelaide
Wildtrak
Hi
fuses?
BlackVXGTS
Melbourne, SE
Also check relays. Test that each fan motor is working properly by hooking up a test lead from the battery to the fan electrical connections.
RWD4ever
Gosnells
VS3 ute
It is also possible that the motor is kaput after 20+ years. Get somebody to turn on aircon while you watch the fan. Does it kick slightly, but not keep turning when compressor comes on?
