pete30nz
- Mar 21, 2011
- 550
- 101
- 43
- Age
- 43
- Location
- Christchurch, NewZealand
- 1994 Vr berlina 3.8 v6 , 1996 VS executive 3.8 v6
If you’re worried about the regulator, pull the vacuum hose, blow it out and check for fuel presenting to the hose (which would be caused by a failed diaphragm), and clean the hose connection on the plenum by poking some coat hanger wire into it and squirting with carby cleaner. Like Losh1971 says though, the absence of fuel odour suggests it’s probably OK. Leakage or blockage of the vacuum line can play up during start and idle. Had this once but swallowed whatever was blocking the hose so can’t tell you what it was. Seven years of perfect operation since though.
I will try these blockage pointers and post back.
