Vs v6 compression test
juzzyx
04 VY Wagon
I just completed a compression test on my 96 Equipe V6 and I'm just wondering if the results of the test seem a little high. The results are in PSI
6-200 5-190
4-189 3-210
2-193 1-188
Any insight will be greatly appreciated. Thank you.
Brett_jjj
Tamworth NSW
vs commodore
Mate as long as they are not low,which they arent,about 100 PSI (689 kPa) is the minimum compression reading. And as long as the highest reading is not greater than 30% of the lowest reading,its all good.That motor should have a fair bit of life left in it yet..
hako
Donating Member
78
Toowoomba SE QLD
VS11 BT1 V6
They seem pretty good to me.....
juzzyx
04 VY Wagon
Thanks for replying. I was just a bit curious because I've been thrashing it a fair bit lately.
juzzyx
04 VY Wagon
Gearbox
Wow... I just replaced my leads. 1 and 6 had 14mega ohms of resistance!!!. and the lowest one was 5k ohms.
The new ones I put in make so much difference! the highest (and longest) measured 0.9k ohms and the lowest one (and shortest) measured 0.56k ohms.
My car is so much smoother and responsive its unbelievable. Bottom end torque has been heavily increased, it does pull a little better top end but is not as noticeable. Also for some strange reason it has stopped getting really hot before the fan kicks in, the fan now kicks in on 3/6 of the temp gauge when before it was 5/6. It now drives like my mums VY. By the way my car is bog stock. Doesn't ever have a CAI.
Anyway what I wanted to ask about was the gearbox. Am I correct in saying 1st takes you to 76k/pH and 2nd takes you to 132k/pH? That's what it feels like. I put the shifter in 2nd and she found another gear after 76k/ph. I was under the impression that 2nd takes you to 76k/pH and 3rd takes you to 132k/pH. However considering that its a four speed and after flooring it 3 times I believe it is 1st that takes you to 76k/pH.
Is this correct?
